John (Jack) Clark's Web Site
Date:  1-11-2011
Number of Hours:  3.00
Brief Description:  Installed Other Rear Pedal Linkage Bar
Installed Other Rear Pedal Linkage Bar and switched the clevos bolts of the rudder pedal assembly to be faithful to the drawings. I had installed the clevos bolts with the short one in the long one's position and Visa Versa. In that configuration, the bolts rubbed on the right later lower extension of the fwd bagage compartment. The switch should fix the problem.
Two Bar Instead of One
