John (Jack) Clark's Web Site
Date:  10-5-2010
Number of Hours:  0.00
Brief Description:  Modified Front Throttle for Clevos Pin Access
Modified Front Throttle for Clevos Pin Access. This was done by drilling another hole with a UniBit at the location on the front throttle for the clevos that attached the rear throttle connection rod to the front throttle. Without this modification, I could not attach the rear throttle connection rod clevos without disassembly of the front throttle. This was definitely not practical with all of the small pieces and closed space. Now I can see the hole for the clevos and can place the pin and cotter pin with easy.
Elongated Hole Front Throttle
