John (Jack) Clark's Web Site
Date:  9-26-2010
Number of Hours:  6.00
Brief Description:  Rough Connected the Front and Rear Throttle
Rough Connected the Front and Rear Throttle without any binding of the connecting rod on any of the bulkheads. I had first created the holes in the involved bulkheads using the installation drawings/templates. By the time I had installed the front throttle with the spacers, it became obvious that these holes were useless and the actual openings needed to be more inboard and inferior. The Front Throttle Mounting Plate needed to be considerably modified by opening up the aft end by elongating the aft lightening hole.
F-804 C bulkheads
F-804 C bulkheads
Aft Throttle bulkhead hole
Aft Throttle
Aft Throttle
