John (Jack) Clark's Web Site
Date:  6-14-2012
Number of Hours:  1.50
Brief Description:  Cut a Hole in the Firewall for the Throttle Cable
Cut a Hole in the Firewall for the Throttle Cable. I used a 1.125" metal hole saw. After cleaning up the edges, I drilled the screw holes for the swivel metal grommet firewall passthrough for the throttle cable. The grommet was install with the throttle cable at least temporarily. I need to put some fire block between the grommet and the firewall.
Throttle Cable Grommet Hole
Throttle Grommet
Throttle Grommet
Inside View of Throttle Cable
