John (Jack) Clark's Web Site
Date:  6-12-2012
Number of Hours:  1.50
Brief Description:  Attached Throttle Cable to the Throttle Lever
Attached Throttle Cable to the Throttle Lever. I was not getting very much cable movement as far as total throw. It appears that the cable bracket to which the sheath of the cable is secured is too close to the throttle lever. This is preventing the full range of motion of the throttle lever with this cable. I will need to move the bracket several inches away from the throttle lever to be able to secure the outer sheath at a length that will permit full cable movement.
