John (Jack) Clark's Web Site
Date:  3-6-2012
Number of Hours:  1.00
Brief Description:  Troubleshoot Alternator Field Fault
Troubleshoot Alternator Field Fault that turned out to be nothing more than turning off the fault detection of the circuit in the Vertical Power System. The circuit draws so little that the system detects it as a fault is it does not see a certain amount of current for a short time (5 sec.) With the fault detection option off, the problem is solved.
