John (Jack) Clark's Web Site
Date:  9-16-2008
Number of Hours:  2.50
Brief Description:  Assembled Rudder pedal assembly
Assembled Rudder pedal assembly to insure the outside to outside measurements of the attachment angles are 15 1/4". Had toe grind the WD 827 brake arm cylinder to achieve the correct length.
Grinding Brake Arm Cylinder
15 1/4" outside-outside length
