John (Jack) Clark's Web Site
Date:  1-13-2008
Number of Hours:  2.50
Brief Description:  Clecoed the Fwd Bottom Skin in place
Clecoed the Fwd Bottom Skin in place. All tucked surfaces have been at least sprayed with Zinc Oxide though most have been surface converted also.
One problem was encountered. The one leg nutplates that I installed on the F-815C Outbd Seat Rib Angles' aft most holes are preventing the insertion of a cleco. I'll have to remove the nutplates before I can rivet the adjacent skin holes. I had installed them while the mid side skins were off because the work space for the nutplate insertion was limited by the skin. It will be difficult to remove the nutplates with the skin in place. I'll probably pop rivet these nutplates back on when I replace them.
Fwd Bottom Skin Clecoed on
