John (Jack) Clark's Web Site
RV-8A
Clecoed the Aft Side Skins in place
Surface converted then primed the contact areas of the F-807A bulkhead. Clecoed in place and then riveted the F-817 L&R Outbd Seat Ribs to the F-807A.
Riveted the F-818 L&R Rear Baggage Ribs to the F-807 Bulkhead and F-814 L&R Inbd Seat Ribs after riveting the F-818B Seat Rib Angles on the F-818 L&R.
Added nutplates to the F-888 L&R Mid Longerons, the inspection plate opening on the F-824 L&R Aft Side Skins and the F-818B Seat Rib Angles.
Back riveted the F-888 Mid-Longeron onto the F-824 L&R Aft Side Skins. Sprayed the contact surface with Zinc Oxide Primer.
Lt Baggage Floor Rib riveted
Mid-Longerons riveted in place
Lt Aft Side Skins attached
RV-8A Home
Brakes
Cooling System
Cowling
Electrical System
Fiberglass
Finishing Kit
Flight Control Syste
Forward Baggage Comp
Forward Top Skin
Heating System
Lighting
Oxygen System
Painiting
Sensors
Ventilation
Windscreen
