John (Jack) Clark's Web Site
Date:  8-21-2011
Number of Hours:  4.00
Brief Description:  Built the Prop Contoller Harness
Built the Prop Contoller Harness connector. Two wires for the Airframe Ground and the (-) Ground (Shield ground) were ran to the area that will have the Forrest of Tabs Grounding on the firewall. The power came from the 4 amp circuit breaker. I soldered an extension on the Prop Sensor wires using 3 x 22ga. shielded wire. This leaves the prop motor power wires to be extended. These I will solder tomorrow.
Spliced Sensor Wire Extension
Prop Connector Wired
Looking Forward
Looking Forward
