John (Jack) Clark's Web Site
Date:  9-1-2006
Brief Description:  Attached Lt tank outboard sender and vent line
Attached Lt tank outboard sender and vent line. The vent line connector was installed with proseal. The vent line nut was torqued to 50 inch-lbs. Terminals were put on the fuel sender wires going to the inboard sender. The terminals to the inboard sender were then connected and prosealed per instructions. Tomorrow, I'll acchach the inboard sender after the proseal cures a bit.
Vent line connected and sealed
Terminals attached to plate
Lt inboard sender plate attached
