John (Jack) Clark's Web Site
Date:  2-8-2010
Number of Hours:  8.00
Brief Description:  Wired the Front and Aft Grips together
Wired the Front and Aft Grips together at the terminal strip.
A d-sub connector was put on one end of a pigtail connected from the terminal to the front grip. This connector will be connected to the d-sub connector that will be put on the cable stub from the front stick. This will allow for the disconnection and removal of the front stick in the future as needed.
The final product of the termonal wiring was functional but not acceptable. I started with the front and aft cable ends next to each other. From here, I ran common wires from each cable to a terminal location. The final problem was that I had a "bird's nest" of wires between the cable ends and the termonal strip. These wires could be secured from moving freely and rubbing on adjacent surfaces but this would be the wrong long term fix. I will have to reconsider this instrallation.
D-sub connector on pigtail
Connections made to terminals
"Bired's Nest"
