John (Jack) Clark's Web Site
Date:  1-1-2010
Number of Hours:  3.50
Brief Description:  Ran the E-Bus Power for the VP CU
Ran the E-Bus Power for the VP CU. This wire has to either come directly off of the battery or the hot side of the Main Battery Contactor. I decided to include the wire in the Positive Cable terminal at the 200 Amp ANL. This reduced the wire run slightly and simplified the addition of the inline fuse.To do this, I had to re-construct the main Battery Positive Cable so as to include the 14ga. E-Bus wire. This wire runs to the J-4 Pin1 position, via an inline fuse. After including the wire in the Positive Cable Lug, the lug and wire were secured with a piece of adhesive lined shrink tube.
The inline fuse holder was made by crimping the metal fuse holders onto the 14ga. wire and then putting a spot ot solder on the wire/holder junction.
ANL terminal lug and 14ga wire
Inline Fuse Holder
Inline Fuse Holder
Fuse Holder in Place
