John (Jack) Clark's Web Site
Date:  12-20-2009
Brief Description:  Made Cables from Contactor to Bus Block
Made Cables from Contactor to Bus Block. The cable from the Main Contactor to the Bus Block is a #6 cable with one end having an 5/16" hole in the lug for the contactor stud and the other end hving a 3/16" hole for the Bus Block stud.
Also made a #6 cable to run from the Bus Block to the Power Stud of the VP CU.
Rt cable from Contactor
Lt cable to VP CU
Lt cable to VP CU
Battery Cable through bushing
