John (Jack) Clark's Web Site
Date:  12-16-2009
Number of Hours:  1.00
Brief Description:  Fabricated/Installed the Bus Block Mount
Fabricated/Installed the Bus Block Mount to the left of VP CU. This will be used to distribute battery power to the CU, a Fused Terminal Block and any other device that will need battery power independent of the VP CU.. I installed the Bus Block to reduce the number of cable lugs that need to be attached directly to the Main Battery Contactor stud for power distribution.
Cut
Cut
Formed for stiffness
Drilled
Drilled
