John (Jack) Clark's Web Site
Date:  5-13-2009
Brief Description:  Re-screwed the Left Tank to the wing
Re-screwed the Left Tank to the wing using some straps to pull the tank up tight. There had been an increase in the gap between the tank and the wing skin since I had tried to remove the tank for the sensor installation. After using the straps, there was a slight improvement in the tank position on the wing. The gap overall is quite small.
