John (Jack) Clark's Web Site
Date:  7-8-2008
Number of Hours:  2.50
Manual Reference:  8-54+55
Brief Description:  Attached, balanced VS rear spar
Attached, balanced, drilled VS rear spar. First, cut 9/16" off of the front spar then cleaned up the edges.
Drilled a locating hole in the rear spar per plans and used this hole to cleco the VS to the F-812B Angle/Control Stop center hole. Measured from the aft tips of the HS to the aft top tip of the VS, adjusting the VS until I had an equal distance of 62 5/16" on each side.
Drilled/clecoed centering hole
Right HS tip measurement
Left HS tip measurement
