John (Jack) Clark's Web Site
Date:  6-11-2008
Number of Hours:  2.50
Manual Reference:  8-52
Brief Description:  Assembled the F-8113 Mid-Cabin Assembly
Assembled the F-8113 Mid-Cabin Assembly by match drilling the F-8113A L&R Console Side Ribs to the F-8113B L&R Mid-Cabin Covers then deburring and surface converting the bottom surfaces of the pieces. The #40 holes were dimpled then riveted together.
The above assemblies were clecoed in the fuselage and the outboard four hole were drilled to #19 holes and the holes were deburred.
I skipped steps involving the fuel selector valve because I'll be installing a Andair valve that I don't have at this time.
Bottoms converted & Sealed
4 Outbd holes drilled #19 size
