John (Jack) Clark's Web Site
Date:  2-7-2007
Number of Hours:  1.50
Brief Description:  Cut the aileron push/pull tubes
Cut the aileron push/pull tubes. Used a pipe cutter that gave a good finished edge but tended to close the end diameter enough to make the insertion of the rod ends into the pipe more difficult. I couldn't use the pipe cutter on the powder coated tubes that connect the bellcrank to the aileron because it crushes/cracks the power coating. I used a hacksaw with good results.
Primed the inside of the large tubes by pouring and slowly rotating primer inside the tubes.
Orderd missing AN316-6 jam nuts needed for the larger tube.
Pipe cutter used to cut tubes
