John (Jack) Clark's Web Site
Date:  11-19-2006
Number of Hours:  4.50
Brief Description:  Attached the Lt tank and installed tie down loops
Attached the Lt tank and installed tie down loops. To install the loops, I had to extend the tap of the tie down brackets about 3/8" before the tiedown ring would flushly seat to the skin and yet be tight in the bracket. Care was taken not to tap the hole too much otherwise the ring's threads would be too easy to turn in the bracket and the ring would not tighten. With the small gap between the skin and the tiedown bracket, the skin would dimple inward under the ring as one then tried to tighten the ring.
Left tank on the spar
Right wing tiedown ring
Left wing tiedown ring
