John (Jack) Clark's Web Site
Date:  8-28-2006
Number of Hours:  1.50
Brief Description:  Connected the terminals to the Rt inboard sender
Connected the terminals to the Rt inboard sender plate fo the capacitance fuel sender. Working area is tight and there is a need to position the terminal is such a way as to prevent the terminals from hitting the vent line and to insure good contact between the terminala nd the plate. After making the connection, the nut, screw ends and the terminals were coated with proseal. Tomorrow, I'll connect the plate to the second tank ribs.
Rt tank inboard plate terminals
Screw head sealed
Screw head sealed
Closer look of prosealing
