John (Jack) Clark's Web Site
RV-A8
Attached the Rear Spar Inboard Stiffeners
Attached the Rear Spar Inboard Stiffeners.
Attached the Rear Spar to the Left Spar Ribs.
Match drilled the #30 holes in the Rear Spar Inboard Doublers that needed drilling.
Countersunk holes in the Inboard Spar Stiffeners per Instructions. Countersunk #40 holes in the Rear Spar Doublers to accept the top skins.
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
