John (Jack) Clark's Web Site
Date:  7-12-2012
Number of Hours:  1.50
Brief Description:  Test Fit the Rudder to the Empennage
Test Fit the Rudder to the Empennage after polishing the rudder. From the alignment of the top Vertical Stabilizer cap and the top cap of the rudder, it's apparent that rudder needs to be adjusted to better align the top caps. This will also increase the gap between the VS cap and the Rudder cap.
Rudder Temp. Attached
Mis-aligned Caps
Mis-aligned Caps
Missing the Needed 1/4
Missing the Needed 1/4" Gap
