John (Jack) Clark's Web Site
Date:  6-15-2012
Number of Hours:  3.00
Brief Description:  Finished the Throttle Cable Installation 1
Finished the Throttle Cable Installation. I moved the cable bracket about 3" away from the throttle lever. This corrected the limited lever throw. I had to fabricate the a mount for the cable at the throttle body in order to be able to secure the cables sheath. After much frustration, I was able to insert the throttle cable and rear throttle push/pull rod clevos pins into the throttle lever from the rear of the lever. I then was able to insert cotter pins after more frustrations. The good news is that the job is done and it works well.
MakingThrottle Body Mount
Finished Product
Finished Product
Cable Connected to Throttle
