John (Jack) Clark's Web Site
Date:  1-3-2012
Brief Description:  Made Several Firewall Penetrations
Made Several Firewall Penetrations.
Made a 1.5" opening for the engine control cables to pass through the firewall. I attached the pass through fittings fabricated from the stainless steel hand rail. Fire Block Sealant was applied to the firewall attachment before attachment.
Installed a firewall pentration for the passing of the manifold pressure to the EIS manifold sensor that I mounted just above the heater. The space seems to be well suited to the mounting os the sensor and the pass through.
Engine Side of Pass Through
Cockpit side of Pass Through
EIS Manifold Pressure Sensor
