John (Jack) Clark's Web Site
RV-8A
Soldered 10K Ohm Resistors in Keep Alive Wires
Soldered 10K Ohm Resistors in Keep Alive Wires for the GRT Displays' Clocks.
Soldered a wire on the tray for the PS Engineering PS-5000EX Audio Panel. This wire will be run to the Grounding Hub.
10k Ohm Resistor
GRT Display Clock Power
Keep Alive Power From VP CU
RV-8A Home
Brakes
Cooling System
Cowling
Electrical System
Fiberglass
Finishing Kit
Flight Control Syste
Forward Baggage Comp
Forward Top Skin
Heating System
Lighting
Oxygen System
Painiting
Sensors
Ventilation
Windscreen
