John (Jack) Clark's Web Site
Date:  3-2-2011
Number of Hours:  1.00
Brief Description:  Made Left Side of the AHRS Mount
Made Left Side of the Attitude Heading Reference System (AHRS) Mount. This will have the Aft end, which consists of a piece anodized aluminum channel used to mount the avionics stack, mounted to the Instrument Panel. The Channel piece will allow for pitch adjustment of the AHRS to match the angle of the aircraft fuselage. The forward end will be attached later to the F802-VPP Fuselage Bulkhead Brace. With the avionics in the Panel, the Panel leans forward. The Instrument Panel will need to be fixed in place by the top skin before it can be determined the location of the forward end of the mount. A piece of aluminum sheet riveted between these mount supports will form the surface for mounting the AHRSs rigidly to the aircraft. Several pieces of angled aluminum will be added to stiffen the mounting surface.
Left Mount Support
Left Mount Support
Channel for adjustments
Referenced to a 6
Referenced to a 6" ruler
