John (Jack) Clark's Web Site
Date:  1-28-2011
Number of Hours:  3.00
Brief Description:  Cut the Panel Opening for the Bottom EFIS
Cut the Panel Opening for the Bottom EFIS. It turned out OK also. What I did discover is that there are size variances between each display. To make both fit, I had to enlarge the holes slightly since on of the displays is slightly larger then the other.
Steel filing fence
Steel filing fence
