John (Jack) Clark's Web Site
Date:  1-16-2011
Number of Hours:  4.00
Brief Description:  Used Hangers to Finish the Switch Panel Wiring
Used Hangers to Finish the Switch Panel Wiring. With a fresh mind and outlook, the solution to the wire run in the vicinity of the switch panel inslude the use of hangers to support the wires on the outside path of the switch panel, below and outboard to the switches of the panel, The wires are still tight as they run under the panel cover but none of the wires interfere with the switch installations of the panel.
Wire Hangers on the Right
Dimmer wires
Dimmer wires
