John (Jack) Clark's Web Site
Date:  11-7-2010
Number of Hours:  1.50
Brief Description:  Installed a Backup Fuselage Ground Wire
Installed a Backup Fuselage Ground Wire that runs from a piece of aluminum angle the is riveted to a bare section of a lower rear longeron. The #6 cable runs a short distance forward to the Aft Grounding Terminal mounted to the right outboard seat rib.
Bolted to Riveted Angle
