Riveted mounting angles and plate nuts to battery box. Mfg battery hold-down assy. Temp mounted battery box. Mfg relay backer bracket and riveted to firewall. Drilled gasculator bracket to firewall. Dimpled and countersunk as required. Need to prime bracket before final riveting to firewall. Also prepared center rudder pedal pivot block for installation-- fitted center pivot support to firewall.
