Mfg and installed strobe light power supply mount in aft fuselage. Installed test panel, test fit for instruments and cut subpanel for clearance for SL30 and glove box. Cut left support for Skyview display clearance. Been doing some preliminary harness wiring for autopilot and audio systems.
And no-- the panel will not be blue---that's the protective plastic covering.
