Brief Description: Remove LG bolts that were too short
Since the 2 installed bolts were going to be a little too short and I had received the new, longer bolts, it was time to remove the old bolts and prep the fuselage for the rotation...again.
If you are using a one-piece Grove gear on your RV-8, make sure to use the NAS6606-36 bolts.
