Brief Description: Reassembled the Rudder pedals and re-installed
I put the rudder pedals back together - using pictures I took before I took them apart - which helped me know the proper washer spacing to use. Of the 6 bolt/screw combinations, five of them went together easily, but the 6th one took most of the time trying to get the castle nut in the right place, not too tight, not too loose, and getting the cotter pin in. Then I re-installed the rudder pedal assembly into the fuse and torqued the bolts as there are no nuts.
