Back in the shop after a long layoff and I was glad to be back out there. I turned the heat on in the garage as it was in the mid-30's and waited until it got up to the low 40's until I got to work - outside air temps are topping out at 29.
I worked on getting the rudder pedal extensions added to the rudder pedals. I first countersunk the rudder pedal holes so there would be a smooth surface on the foot. I then opened up the holes for the #8 screws and drilled the holes in the extensions for the nut plates. The nut plate holes were then countersunk as the extensions need to be flush against the back of the rudder pedal. Then I riveted the nutplates to the extensions and screwed the extensions to the pedals.
finished left rudder pedal - back of right rudder pedal
