Jims RV-8
Date:  2-7-2017
Number of Hours:  1.30
Manual Reference:  8-67
Brief Description:  Upper / Lower front baggage bulkheads
I started with the next step which is to cleco the upper and lower baggage bulkheads together. It was then that I noticed the the lower bulkhead really needed to be painted on both sides as it will be visible from the pilot/co-pilot point of view. So, before clecoing and riveting the parts - I need to pause and paint. (See pic #1)
I decided to install some more of the interior parts/skins to see if there were other parts that needed to be painted as I knew that there was some touch-up work on some of previously painted parts so a look at the weather shows that Saturday will be prime weather for painting.
I decided to paint the inside of the lower baggage area as I will be installing the smoke tank down there and it would be better to have that panel painted in case of smoke oil spoils. (See Pic #2)
Looks like I painted the wrong side of the aft baggage shelf, so add that one to the list to be painted. I also needed to drill, deburr, smooth, scotchbrite, clean and prime the small attach brackets that hold the upper portion of the aft baggage door.
lower baggage compartment skin
aft baggage shelf
aft baggage shelf
