Jims RV-8
Date:  1-23-2017
Number of Hours:  1.50
Manual Reference:  8-60
Brief Description:  1. Rudder control cable install
A good night in the shop... I started threading the rudder cables in from the rear of the fuselage while clicking in the snap bushings as I went thru each bulkhead. The 4" inch tubing remains at the back of the fuselage and the 13" tubing is near the front - so I made sure to orient it correctly. At the front cockpit floor, I put in the 13" tube, cutting a slot in the aft end of the tube and zip tying it to the braket/snap bushing. Easy breazy.
tubing, snap bushing, bracket and zip tie
cables installed
cables installed
connected to rudder
connected to rudder
