Brief Description: Priming the exterior of the F-841 pushrod
The VA-101 Threaded Rod Ends and the F-841 Pushrod are bare aluminum and must be primed inside and out. They are primed after assembly because with the close fit of the threaded rod ends and the pushrod, it can be very difficult to assemble after primer is applied to the parts. So, As instructed, I primed the exterior of the pushrod and threaded rod ends after using scotchgard to scuff the entire pushrod/threaded rod surface. I hung the pushrod assembly outside from some clothes hangers and rotated the pushrod after priming a side.
