Jims RV-8
Date:  1-14-2016
Number of Hours:  0.50
Brief Description:  SS Cooling Ramp v2.1 #5
Tonight, I removed some of the excess metal on the aft end of cooling ramp so that the fit / flush will be a little better. I ended up using the manually cut end of the stainless for the aft end by mistake...but the cut wasn't too bad, so I just removed the extra and it lines up well now.
Next,,I drilled the aft holes in the cooling ramp. With careful measurements of the two outboard holes made, I drilled and then clecoed the aluminum cooling ramp in place and then I had a template to drill the remaining holes. Then it was deburring and dimpling to have one more set of holes made in the cooling ramp.
aft section of hole done
