Brief Description: Stainless Steel Cooling Ramp Mod #3
Did some more measuring to get the rest of the holes drilled. I put the aluminum ramp back in place to test the fit with the bottom skin and it does fit nicely so I will use that as a template for drilling the holes in the stainless version. (See pic #2)
Drilled the 2 holes in the front sides and the 3/32" holes across the aft end using the aluminum ramp as the template. Didn't get holes correctly on the one side as the gap is a little bigger on the right side, but perfect on the left side. Hmmm.
