Jims RV-8
Date:  7-26-2015
Number of Hours:  1.00
Manual Reference:  8-42
Brief Description:  thinning left side of landing gear
I pulled the gear down off the fuse after marking where on the left side I needed to shave some material. I took my time and only took off a little bit at a time so as not to take off too much. after a few iterations on sandpaper, lighter sand paper, scotchbrite pads I had it just to the point where it would barely slide down all the way along the gear. I was even able to get my precision punch inserted into all four holes in the attach brackets and the wear plates. If I were sure that the holes were exactly where I wanted them I could start drilling them out. But I am not there yet and I want to have the rivets / screws done as I said before and I want to really research and make sure I am completely sure about the next steps. So the next few days will be all about the research and then on to the measure, measure, measure, drill.
better, but not quite there
there we go,,,
there we go,,,
looking good.
looking good.
