Jims RV-8
Date:  2-8-2015
Number of Hours:  1.00
Manual Reference:  8-37
Brief Description:  A few more rivets and ready to "roll"
So today I did a few more rivets on the aft end of the fuselage because I figured that I could reach to both sides of the rivets. It works pretty well until you get to the rivets on the fuselage curves - then it takes eyes on both sides.... so that's where I stopped riveting and will wait for by bucking partner.
In preparation for rolling the fuse over to rivet the bottom skins, I needed to remove the baggage bulkhead and pull out all of the tubing, especially the right tank tube so that I could re-cleco the center section.
Rear end rivets - all but 4 on the bottom
outside view with fewer clecos
pulled out the tubing, clecoed center section
