Jims RV-8
Date:  12-23-2014
Number of Hours:  2.50
Manual Reference:  8-36
Brief Description:  Add unions to fuel vents - fuse to sawhorse
I got the unions attached and the union fittings riveted on to the LG box side. I figured the additional strength of having a bracket holding the union would be a good thing so I held the bracket and drilled the two holes with the angle drill. After drilling I test fit with the clecos in position and then deburred and countersunk the holes. On the right side I overcountersunk a bit - so I opted for using a AD426-4 rivet instead of the AD426-3.
Also moved the fuse to the DRDT2 table that I cut down a bit. I had the help of Holden and his friend Zane - so it was an easy move.
riveted fitting to LG box forward side
union on fuel vent
union on fuel vent
lowered to sawhorse/table
