Jims RV-8
Date:  9-26-2014
Manual Reference:  8-27, 29
Brief Description:  Drilling Fuse Skins - Center section
I was finally able to go back and final drill the center section flanges to the F-822 skin and the F-826, F-827 seat rib skins. I didn't feel comfortable moving that big fuse structure to a gap that I could access the center section bottom so I waited, and now that the aft section was off, I went back a did that step.
With the center section drilled, I could then pull off the seat rib subassembly, recleco the F-822 skin and countersink the two rows of skin/center secion flange.
Then it was more deconstruction of the front side skins - while keeping the sub structure / skeleton in tact.
rear view
rear view
even less airplane but making progress
