Then when clecoed together the seat belt assembly - I noticed that I had riveted the seat belt brackets in facing the wrong way... so I had to drill out and re-rivet those.
After I fixed the orientation I drilled the 3/16" holes to #12 between the seat belt bracket, seat belt bracket assembly, and lower longeron.
