Brief Description: Forward Fuse - Drill the Right Lower Longeron
Today I was able to get the right lower longeron installed and drilled. For those of you that are drilling the lower longeron, make sure you cleco in the gusset at the center section. This will help to align the aft portion of the lower longeron. I did this on the left side but failed to do it on the right side. I ended up drilling the aft side of the longeron inward just a bit and then had to put a jog in the gusset to get it to fit. Other than that, all went well.
