Jims RV-8
Date:  8-10-2014
Number of Hours:  1.10
Manual Reference:  8-16
Brief Description:  Forward Fuse
I wasn't quite ready to jump into the upper longerons withouts some more studying, so I jumped to the forward fuse sections. I bent to the contour the center section brace and the landing gear brace along the top. The instructions explain how you clamp a 2x4 to the workbench with a 1/8" spacer and put a gentle bend at every 1/2" to match the contour of the curve
marked and bent
marked and bent
test fitted
test fitted
