Jims RV-8
Date:  7-19-2014
Number of Hours:  1.80
Manual Reference:  8-13
Brief Description:  Seat Rib Sub 5) Cleco, Drill entire subassembly
Now that the rear spar is drilled I added the bottom skins to the assembly and drilled the skin to rib rivet holes. I then unclecoed the entire assembly and broke the edges on the bottom skins. I also spread the opening a bit on the bottom flange, in the center of the F-806B-1 to allow some extra room for the middle skin rivet to be bucked. I saw this as a helpful hint from someone - sorry that I don't remember who it was.
All clecoed & Drilled
disassembled - ready for deburring
