Jims RV-8
Date:  7-11-2014
Number of Hours:  3.30
Manual Reference:  8-12
Brief Description:  Seat Rib Sub 2) F805D & fwd. inbd seat ribs
I made the F-805D brackets - making sure to make a left and a right. The brackets are 2" long but are sourced from the 15' angle that comes packed with the 2) 18' longerons. Based on what I have read, the fact that Van's gives you three 15' angle to make parts with is a throw back to before the RV-8 kit was prepunched and all of the smaller longerons had to be made from un-punched angle. A bit of overkill - but ok.
After the brackets were made I clecoed together the forward inboard seat ribs that have prepunched angle attached - with nutplates that were drilled/countersunk. After the seat belt brackets were clecoed onto the ribs - everything was drilled.
3/4" x 3/4" angle
finished F-805D brackets
clecoed/drilled inboard seat ribs
