Brief Description: Center Section - 2) Forward Bulkhead
Continued the F-849 forward control mount - measuring, scratching my head, etc. When it was time to make the cuts, i decided that it was past time to get a new band saw blade - so I went to the big box store and picked one up. I also picked up some hardware for the wing spar spacer - but that comes later. With the new blade installed the control mount was easily cut, then polished and finally mounted - leveled and drilled (second hole) on the center section.
I also prepped the forward bulkheads - and associated parts. The plot goes like this - flute the bulkhead flanges, cleco to the forward center section, final drill all common holes, uncleco, debur.
